Welcome to Beoworld !
Check that the mains voltage setting switch is set according to your local mains voltage.
Still no luck - replace capacitors. A kit is available.
TR27 is not the reason for the humming.
Aging capacitors and the board mounted rectifier are the greatest candidates.
