Latest post 12-31-2008 2:06 PM by Peter. 1 replies.
Page 1 of 1 (2 items)
  • 12-31-2008 11:53 AM
    Beogram 8002 Diagnosis
    My Beogram 8002 plays faint music out of one of the channels.  I confirmed that it is not the receiver or amplifier.  Is this likely to be a problem with the MMC cartridge or is there anything else that I should be checking?  Given the unique multi-pin plug, I'm not sure how to verify that the cable is properly functioning. Thanks for your help!
  • 12-31-2008 2:06 PM In reply to
    Re: Beogram 8002 Diagnosis
    Probably the cartridge but I suppose it could be the muting circuit. The obvious way to test is to use a cartridge that you know is working but I guess one is not available. A continuity tester on the wiring would be one way.
