Back to the matter at hand- The drive wheel (on which the platter rests) is scraping on the frame, or, chassis. My feelings are that it's the bearing, but, is that a non-servicable item? i have another sub assembly, but, if this the problem can just the bearing carrier be replaced, or, rebushed. Thank you again, Dan
FIXED IT!!! THE FIX-I USED GREAT CAUTION ON THIS ONE. with sharpie type marker, hold pen at area of platter wheel and wait to hear scraping. In conjunction of noise with actual scrape on frame touch wheel with marker, to establish point of problem. Now, CAREFULLY,and, gingerly (with unit turned off) use slide jawed pliers-yes, pliers, and, grip inside edge of drive wheel -between spokes(where black plastic shield rests) and, bend or twist upwards. The object being is to take low spot out of wheel without cracking, breaking, or distorting wheel. good luck
ONE PROBLEM-ER-CHALLENGE SOLVED ANOTHER ARISES. TURNS ON, ROTATES, ARM SWINGS OVER, ARM DOESN'T DROP, RETURNS TO STORED POSITION. OH WELL. I AM DRIVEN!!!
