Latest post 05-24-2007 7:23 AM by Beonut. 5 replies.
Page 1 of 1 (6 items)
  • 05-22-2007 7:36 PM
    Possible Solution to BV 7 PCM problem
    Guys have just recived this from a guy called Dirk on another website.  I will contact my dealer and ask if this can be done and i will info you straight away.  Here is the reply i got......
    Hi Mr. Carl, PCM calls "Pulse Code Modulation" or LPCM for "Linear Pulse Code Modulation". The Systems NTSC and/or PAL absolutely needed the PCM (2 channels). A new SW, I mean "Software (7.5)" is now available for the BV 7 to solve this problem Nr. 8 ! Your Dealer can it be update via PUC (or STB)
    Kind regards, Dirk
    lets hope and pray it works.
    Carl
    Carl Sheerman
  • 05-22-2007 10:23 PM In reply to
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    Re: Possible Solution to BV 7 PCM problem
    Carl,
    Please post your experience once you have updated the software. It would be geat to have a simpler option.
    Beoaus.
  • 05-23-2007 12:31 AM In reply to
    What was the problem?
  • 05-23-2007 1:47 AM In reply to
    I saw the reply. The bits that come with the software make no mention that it fixes that issue so I will be interested to see if it does!
  • 05-23-2007 4:51 AM In reply to
    Guys have contacted my dealer adn have given him the info.  he is getting back to me ASAP so again lets all wait!!!
    Carl
    Carl Sheerman
  • 05-24-2007 7:23 AM In reply to
    • Beonut
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Essex, UK
    • Posts 89
    I would be surprised if this software will give anything more than 2 channel pcm, to get multi channel (5.1 or 7.1) uncompressed pcm requires an hdmi cable because of the amount of sound data coming from the source which would currently be a blu-ray player only or maybe an HD DVD but not sure. Optical / spdif does not have enough capacity to carry multi channel pcm.
    Cheers
    Peter
    My B&O - BS3, BV4-50, Beomedia 1, BS3200, DVD1, BL8000, BL6000, BL3, BL2, BL7.4
