see my reply to your earlier question !
finger nails also work - top and botton between the fabic panel and its close fitting surround gently ease it out and the panel will spring out - its not difficult!
refitting fit one side then just press other side home - again job done
tony s
I always try to operate using/following the KISS principle -- Keep it simple stupid!
