Have you got a STB-Controller (or PUC) on the BV3? Have you got a DVD1 or another source connected as well?
If yes, then you connect the STB to the TV to the AV Scart and use the STB-C, the HDR1 to the V.TAPE scart, and the V8000 to the back of the HDR1.
I include here the result of the B&O recommendation made using the PCG, for using a STB, HDR1+V8000 and a DVD1
************************* VIDEO SYSTEM SETUP **************************
BeoVision 3 - 28" m/ML
HDR 1 (VR 1)
V 8000 (VR 2)
DVD 1
Set-top Box Controller ( 1 STB )
Connection Video
Connect the aerial to the aerial input of the VR 1.
Connect the aerial output of the VR 1 to the aerial input of the
TV-set using a coaxial cable.
Setting of switch on DVD
Set the switch on the back of the DVD 1 (Y/C - CVBS - RGB) to position RGB
To ensure that the DVD discs are played with the proper picture format,
please perfom this "once only" operation:
Press LIST on Beo4 until v.setup appears in the Beo4 display.
Press GO to display TUNE. Press 1 if the DVD1 is connected directly
to a BeoVision MX television.
Press 2 if the DVD1 is connected to a BeoVision MX via an AV2 Expander box,
or if DVD 1 is connected directly to any other Bang & Olufsen television.
Press GO to store the setup.
Default is mode 1.
Selecting option on the TV-set
Option: OPTION 1 (Factory setting), with Beo4
Press: | Display:
STANDBY + LIST at the same time | OPTION?
GO | V.OPT
1 | Observe confirmation
| from BeoVision
Programming the setup
TV Setup:
To get access to the CONNECTIONS setup menu do as follows:
Press MENU
Select OPTIONS and press GO
Select CONNECTIONS and press GO
Edit the menu on the screen using ARROW UP, ARROW DOWN, << and >>,
until it looks as follows:
CONNECTIONS
V.TAPE V.TAPE
AV DVD
Store the programming by pressing GO.
HDR 1 Setup:
Connected sources should be set up in the following way:
V.MEM / MENU / Setup / Connections
Choose the following from the menu:
V.TAPE
Note!
On TVs with an ML kit it is only possible to connect a decoder to the
TV's V.TAPE socket or the DEC socket of a V 8000.
Only the V 8000 supports video signal pass-through from the decoder
to the TV.
********************* REMOTE CONTROL FOR MAIN ROOM ********************
The recommended remote control is Beo4
The following remote controls may also be used:
Beolink 1000
However, there may be functional limitations if the alternative
remote control is used
Setup for Beo4 remote control:
Beo4's "LIST" must contain the following items in order to be able
to operate the Main Room products.
STAND
CDV (only with S/W lower than 4.0 in Beo4)
MONO (changed to SOUND with S/W 4.0 or higher in Beo4)
AV (only with S/W 4.0 or higher in Beo4)
See Beo4's operation manual page 10/12 on REMOVE and ADD functions
from/to the List
Note!
Beo4 must be equipped with software (S/W) 3.0 or higher.
The software version will be shown in the display of the Beo4 if you press
(STANDBY+LIST) at the same time, and (MENU+GO) at the same time.
