Latest post 12-02-2008 5:21 PM by tournedos. 6 replies.
Page 1 of 1 (7 items)
  • 12-02-2008 3:40 AM
    • augs
    • Not Ranked
    • Joined on 09-17-2007
    • Posts 73
    iBundo pro - iPod/ iPhone - docking station for Beo4/ Beo5
    The new iBundo pro is available from now on:
    Full access to the menu of your iPod/ iPhone. The dock is able to charge all iPod/ iPhones which are charged using USB. This includes the new generation (autumn 2008)
    Link >>>
    Best
    Augs
    Es hört doch jeder nur, was er versteht. (Johann Wolfgang von Goethe)
  • 12-02-2008 4:03 AM In reply to
    Re: iBundo pro - iPod/ iPhone - docking station for Beo4/ Beo5
    Pretty cool.
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 12-02-2008 4:07 AM In reply to
    Nice - are you working on a solution for AppleTV/Mac mini?
  • 12-02-2008 4:09 AM In reply to
    It´s posible to see the ipod menu in the Beovision 7-40 with these dock?
    Beosound 9000 + Beolab 8000 + Beolab 2 + Beocom 6000
  • 12-02-2008 7:16 AM In reply to
    I like the look of the light controller - any chance of a UK version?
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
  • 12-02-2008 8:11 AM In reply to
    yes, that would be nice!
  • 12-02-2008 5:21 PM In reply to
    Steve at Sounds Heavenly:
    From what I understood, it doesn't actually have any direct light controls - instead, it watches IR remotes, and whenever a suitable command is received, it relays them on the 433 MHz band to Intertechno-compatible radio control hardware. I don't know if you have them in the UK or even if they are legal over there, but it's pretty much standard on the continent. The control elements can be switches or dimmers (I don't know if this product can handle dimming). So this would only in effect replace the cheap plastic remote transmitter you normally use for these, the control elements you have to get elsewhere (they are quite inexpensive).
    Anyway, as a short answer, you shouldn't need a special version (apart from the power supply wall plug) Smile
    -mika
