Latest post 04-03-2008 3:26 AM by ChrDH. 2 replies.
Page 1 of 1 (3 items)
  • 04-02-2008 11:13 AM
    • ChrDH
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Denmark
    • Posts 493
    Faulty bass on Beovox S60
    I helped a friend with a old speaker the other day, he said the bass was weak on one of the speakers, so we opened it up and found that the 25cm SEAS woofer was rusty on the magnet and some of the chassie, while the woofer in the other speaker fas fine and worked nicely. I recon the rust have corrupted the copper-threads inside, making the woofer less powerfull. Have any of you expecirenced anything like this with a 30 years old speaker?
    br
    Chr.
    Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
  • 04-02-2008 1:25 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Faulty bass on Beovox S60
    More likely to be a capacitor problem I think. I've seen many cases where dried out caps made one speaker "heavier" to drive than the other.
    If you are unsure, swap the woofers to help diagnosing.
  • 04-03-2008 3:26 AM In reply to
    • ChrDH
    • Denmark
    • Posts 493
    aha, yes, I can just swop the drive units. However, i think my friend have accepted that they are not as good as they used to be. He uses them with a beomaster 2000 (70'ies model) and a Thorens MK320 turntable, very nice sounding all in all.
    br Chr
