1st March February 2012
Latest post 11-30-2008 5:55 AM by metalas. 14 replies.
beaker
- Joined on 06-14-2007
- Posts 526
Re: which receiver to keep the beomaster 4500 type 2965 or the beomaster 5000 type 2321
The BM5000 is a much better amp than the 4500 but I am not 100% sure you can use the BL1000 with it. The 4500 is a much prettier design and will be easier to connect up to other pieces of equipment. In my opinion I would go with the 4500 or even use the 7002 as they are very underated and will probabley sound nicer than the 4500.
metalas
- Joined on 11-22-2008
- Posts 13
the 7002 has the turntable and receiver all in one which I didn't much like the plastic cover is damaged and no needle and they are very expensive I am told
j0hnbarker
- Joined on 04-16-2007
- LS28/GB
- Posts 2,002
The 5000 is by far the better amplifier, though you cannot use the Beolink 1000 with it at all, unless you get one of the ultra-rare code converters that several of the members on this forum are currently actively seeking. If you want to use the 5000 with passive speakers alone (it doesn't have powerlink sockets for active speakers), then I'd keep it and sell the 4500. On the other hand, the 4500 is better looking, so you might want to keep that if looks are your number one priority. What means more to you: looks, or sound quality?
Peter
- Joined on 02-12-2007
- Posts 9,572
I would use the 5000 with the Beogram 3000. You have the MCP so the remote is less of an issue. Much better amplifier, both pre and power. The 5000 was very well made and had a great sound. Yes, it does not work with the modern remotes but if you are planning to use it with LPs, it will be great. Look out for some better speakers if I were you. If you see a pair of S120s, get them! These really sing with the 5000 and are going to help you get the most from your records. Also look for an original Beogram 5000 - again beautifully built and in my view sounds better than the later tangential decks. Should be very cheap though well worth getting a new Soundsmith cartridge at some time.
metalas
- Posts 13
thanks all for your input I may go with the 5000 as I know it was serviced less than a year ago as for buying more gear I may have to recover from my latest blunders and try to sell the unneeded bits first thanks again
Peter
- Posts 9,572
I don't think you have blundered at all! You have bought some good equipment - the 4500 is one of the most popular Beomasters and the Beogram 3000 is also sought after.
burantek
- Joined on 05-04-2007
- SE USA
- Posts 6,214
agreed... no blunders at all! you picked some of the very best pieces in their respective categories! i have the same pieces (less the s50) and i would have trouble narrowing them down. welcome to beoworld! ++++edit++++ just had some clear thoughts regarding your specific desires... i'd sell the 3000, 7002 and 4500 and concentrate on the 5000. take peter's suggestion and find a matching bg5000. that will get you up and running. then you can start looking for the matching bc5000 and cd50 (cd player) and the smaller 5000 terminal. over time, you will end with a great "matched" setup! if i can find the time, i will upload a pic of mine...
Steve at Sounds Heavenly
- Joined on 05-18-2007
- In the cable workshop, Melton Mowbray, UK
- Posts 356
Hi metalas, If you do decide to keep the Beomaster 4500 to use with the Beogram 3000, please bear in mind that you will need a pre-amplifier, as the Beogram 3000 does not have one built in. This is not difficult or expensive to sort out and would give you an excellent system that would work with your existing speakers and also be "future-proof" in that it would accomodate Beolab active speakers in the future if required. Personally, I think that the 4500 looks great as well! Whichever set of kit you decide to keep (I say keep it all!) then I think you have got some great hifi equipment that should give years of enjoyment. Best regards, Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
metalas
- Posts 13
I have just connected the speakers to the 5000, using the radio when I connect to speaker terminals 1 I get nothing it plays on speaker terminals 2 the manual says connect to 1 am I missing something or do I have a gear fault?
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Hi Metalas. If the 5000 is anything like the later 7000, then mute function does not work on Speaker 2, only on Speaker 1. Could it be you have accidently pressed mute on the front panel? Andy T.
metalas
- Posts 13
thanks that got it going but still seem to have nothing from left side on speakers 1, Andy P alias metalas
- Posts 356
Hi Andy, There is a common fault with Beomasters of that age, where the relay that mutes Speaker 1 can fail, causing a loss of sound on one or both channels. I always think that the Speaker 2 output gives a better quality of sound than Speaker 1, even on Beomasters that are not faulty. I use Speaker 2 for my main room output on my Beomaster 3500 and Speaker 1 for my extension room, where no serious listening takes place. If Speaker 2 works, then I would use that connection instead. Best regards, Steve.
metalas
- Posts 13
thanks steve I was a bit worried I'd bought a lemon it does sound good out of speaker 2. Don't seem to get much response from trying to set the time and date on the MCP I'll start by putting in new batteries but I don't think that's the problem might just be me not knowing what I'm doing yet, I may give the 4500 a run and see if sounds better or is easier for this HiFi ignoramus to get his head round.cheers
metalas
- Posts 13
Hi AndyT read your thread on renovating the s120 speakers, great story and picture board, makes me glad we have a really good audio sales and repair shop here in Auckland [Axcent audio] they specialise in good quality audio gear,my s50 speakers that they did the same job on sound great I was interested to hear they will improve as they loosen up, I thought that my $150 less than 50 pounds equivalent was well spent you have the patients of Jove.just an aside my s50 have the overload ,when I look these up on beoworld they don't seem to have this are mine of the last produced , also are you audiofiles out there under rating what sounds like a really good speaker,[ just asking .] Thanks Andy P. alias metalas
Page 1 of 1 (15 items)
