Latest post 11-18-2008 6:38 AM by stefan. 2 replies.
Page 1 of 1 (3 items)
  • 11-18-2008 5:56 AM
    Beomedia 1 setup questions
    If I want to connect a Beomedia 1 to a BV7, the PCG tells me I should connect them using a VGA to DVI adaptor.
    It does not tell me to connect a MasterLink cable, nor a Scart cable.
    Question... how does the TV control the Beomedia 1????
    p.
  • 11-18-2008 6:05 AM In reply to
    • Beogen
    • Top 500 Contributor
    • Joined on 05-12-2007
    • Belgium
    • Posts 135
    Re: Beomedia 1 setup questions
    I've connected mine using the VGA input on the BS3 and also a connection to the existing ML network  so I assume it receives the commands on the ML bus.
  • 11-18-2008 6:38 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    You need a VGA - DVI cable if you have a BV 7-40 MKII. The MKIII got a VGA input. Masterlink and analog audio is also needed. If you have Link-TVs connect the composite-out to composite-in of the Beovision.
    Beomedia 1 will be conrolled by the BV7 via ML in PC mode.
    Stefan
