Hi!
As topic says, my bl5000 display is loose and I want to fix it. How?
regards
I belive a replacement display are rather expensive.
The last time I asked, the display cost over 200€.
I havent changed myself so I dont know if you can do it yourself.
BV10
Glue it back in place.
Regards Graham
I agree. Glue it if it still works.
Poor me, never win owt!
Yess!
the display works. What kind of glue? maybe a permanent as the display is so expensive?
