Latest post 12-01-2008 5:45 AM by timhanna. 2 replies.
Page 1 of 1 (3 items)
  • 11-30-2008 2:28 PM
    Beo4 SAT version and BV7 dvd playback
    I got this old beo4 sat version, can i cant seem to be able to play DVDs using it? i.e. my beo5 will start the dvd playback, but when i press AV on the beo4, it wont... is there another setting instead?
  • 11-30-2008 3:03 PM In reply to
    • V13WNG
    • Top 500 Contributor
    • Joined on 06-11-2007
    • Eastbourne, East Sussex, ENG
    • Posts 200
    Re: Beo4 SAT version and BV7 dvd playback
    Hi Tim,
    You'll need to add 'CDV' to the remote's LIST functions - that should fire up the DVD player. Not sure about controlling it though - sorry!
    M.
    Muchos Gracias Cool
  • 12-01-2008 5:45 AM In reply to
    Thanks A14! It does work, i think ill just use the beo4 for link audio and keep on using my beo5 for tv and dvd... after having the beo5 for some time, it makes using the beo4 strange :)
