Latest post 12-01-2008 10:33 AM by auric. 3 replies.
Page 1 of 1 (4 items)
  • 11-30-2008 8:21 PM
    beosystem 2500 - cd problem
    i have a beosystem 2500.  after i load a cd and press play it takes three or four tries to get it playing.  once it plays it shuts down after a few minutes.  any help?  if it needs professional repair can someone recommend a repair shop in upstate new york/ western mass./ne ct.  hanks.
  • 11-30-2008 10:52 PM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    Re: beosystem 2500 - cd problem
    My advice would be to first try cleaning the laser lens, either with a commercial CD lens cleaning disk or a Q-Tip dampened with rubbing alcohol.  If this doesn't work the problem could be with a capacitor, or the laser might need replacing.  Can't give you too much technical detail here.  With regard to a service facility I can recommend Atlantic Systems in Hanover, MA.  You can google them for a phone number, address, etc.  They're the official Northeastern regional service center for B&O.  Good luck.
  • 11-30-2008 11:25 PM In reply to
    thank you.  will try and will let you know the results.
  • 12-01-2008 10:33 AM In reply to
    Send it to Paul at Atlantic Systems in Hanover Mass. He is an authorized B&O service center.
    Derek
