        1st March February 2012
	    Latest post 11-01-2010 5:16 PM by  Doctor. 11 replies.
								        11-01-2010 9:37 AM
									        sodoi18
								                - Joined on 02-06-2010
								                - USA
								                - Posts 194
										    Loudspeaker/Amplifier Relationship -Beginners Questions
										    I wanted to understand more about the speaker watts, impedence, amplifier volts relationship.
After a quick reading I think I get the relationship. For Example
Lets take a Beomaster 4500 with Long-term max. output power IEC: 2 x 55 W / 8 ohms
This means I can take for example any 8 ohms impedance speaker ( RL 60.2) and match it with the 4500 with no issues or may be the best match as the RL 60.2 can acutally take 75 Watts input by design
Question:
1. What happens if I connect the S45-2 to the beomaster 4500 which are rated at Continuous load: 56 W , Music load: 75 W ( 2. What is the difference here) and Impedance: 4 - 8 ohms
3. If you note the impedance range of S45-2 - does this mean the S45-2 is capable of getting upto 110 Watts if its at 4ohms impedence - I know the impedence is dynamic meaning the watts are too.
Can some one do a better job at this explanation or Do I have it right?
									    Beovox RL 60.2, RL 6000, S45-2, CX 50, Cona, Beolink Passive, MCL2P, BM4500, Beosound 1, Beocenter 2500, Beolab 2500, Besound 4000, Beolab 4000, Beocom 6000, A8, Beosystem 1
									        sodoi18
								                - USA
								                - Posts 194
										    Re: Loudspeaker/Amplifier Relationship -Beginners Questions
										    With above post I am not trying to under play the complex relationship of a loudspeaker and amplifier. All I am trying for is a simpler understanding!
									        Doctor
								                - Joined on 09-14-2010
								                - Posts 555
										    I don't blame you for the confusion. One of the problems is the actual measurement of figures. Around the end of the eighties, B&O started measuring power using different parameters. This caused the Beomaster 5500 to go from being a 55W per channel amplifier to being a 110W per channel amplifier. Clearly nonsense but of no importance as it still sounded just the same! It did however throw the wattage ratings of speakers into disarray. The S45-2 can take anything the BM4500 can throw at it (except distortion!) as the BM4500 has about a 30W per channel amplifier using the old measurements on which the S45-2 is based.
However the whole thing is a little academic. Speakers will on the whole prefer a big amplifier developing lots of undistorted power to a small one struggling and hence distorting. My speakers at home recommend a 25W linit but I have used every B&O amplifier going with then right up to a BM8000. They were all fine. I doubt you will find a B&O speaker that the BM4500 will have a problem with.
On the impedance bit, these figures are on the whole not worth looking at. The impedance varies massively across the frequency spectrum. The S45-2 quotes 4-8 ohms but will vary far more than that. The perfect amplifier will produce more power into low impedances but in reality this will roll off pretty quickly; the Beolab 5000 service manual has a nice chart showing the effect of impedance on power output.
									        sodoi18
								                - USA
								                - Posts 194
										    Does that means that if you apply the similar logic (beomaster 5500) the beomaster 4500 watt out put would also double from 55 to 110?
How could a change in standard of that drastic impact on watts would or was accepted?
									        Seanie_230
								                - Joined on 04-20-2007
								                - Milton Keynes, England
								                - Posts 962
										    if you connect two 8 ohm speakers together (not in series) they in effect become a 4 ohm speaker
Two 6 ohm speakers toghether will become a 3 ohm speaker.
									    Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
									        Søren Hammer
								                - Joined on 01-07-2008
								                - Esbjerg/Denmark
								                - Posts 554
										      sodoi18:
The 4500 is also measured by the "new" standard (RMS?), it is producing 30 watts, just like the 5500 is producing 55 watts in the older standard.
									    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
									        Doctor
								                - Posts 555
										      sodoi18:
No, the 4500 doubled from 30 to 55!!!   It all depends on the method of measurement. B&O simply fell into line with others. Power is mainly a marketing device anyway! Very debatable how important a few watts one way or another is - we tend to use about 1W when listening normally!
									        sodoi18
								                - USA
								                - Posts 194
									        sodoi18
								                - USA
								                - Posts 194
										    Since we are talking about watts - Is MCL2P now a 60 Watts instead of 30 Watts?
									        Large48
								                - Joined on 06-24-2008
								                - London
								                - Posts 455
										    Also if you add a 2nd pair of speakers do you halve the amount of 'power' that goes to each set?
									    Train Hard - Run Fast - Hit to Kill!!!
									        Søren Hammer
								                - Esbjerg/Denmark
								                - Posts 554
										      Large48:
That is right, and if you connect in parralel, just like on a normal amplifer, the impendance will be half of the speakers'
									        Doctor
								                - Posts 555
										      sodoi18:
The MCL2P amplifier is much the same as a BM4500 - so yes!
        Page 1 of 1 (12 items)
