Hi Craig
Thanks for the offer, it gave me the idea that currently i am re covering the frets of 2 rl60-2 's of which one cover is excellent and one with several holes - i may be able to use that fabric - however i'll bear your kind offer in mind!
recently you refurbed some cx100's did you recap em - if not i've located a source so could forward a set!
salut
tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
