Latest post 11-05-2008 10:44 AM by Christian. 2 replies.
Page 1 of 1 (3 items)
  • 11-05-2008 10:11 AM
    • h1npw
    • Top 75 Contributor
    • Joined on 04-16-2007
    • A cricket ball throw from Trent Bridge
    • Posts 776
    Penta advice
    Hi
    I have several questions about Pentas......
    When I get a pair I will be using a Beosound 2500 (obviously active only) or a Beosystem 6500.
    1) Is there an appreciable difference in sound quality between passive and active?
    2) What are the phyisical differences between MK1, 2 & 3 Actives?
    3) Are there any appreciable differences in sound quality between the different Actives?
    4) Do actives suffer from foam rot of the midrange units like passives?
     5) Apart from foam rot and cross-over capacitor replacement, is there anything elso to watch out for?
  • 11-05-2008 10:36 AM In reply to
    Re: Penta advice
    You can think of the active Pentas as a Beolab 150 sandwiched between the bottom plate and the rest of the speaker (you can actually remove it and end up with a Beovox!). Apart from the empty space behind the display window on the passives, the actual speaker columns are identical and so have the same pros and cons including midrange foam rot. I think there are minor differences in the crossovers, though, to keep in mind when ordering replacement caps (see my thread on the subject, I will continue it when I get my new caps).
    The Beolab 150 might be a better amp than the Beomaster 6500 but apart from that, I don't think the actives could have much of an edge over the passives - they still have only a single amp and a passive crossover, unlike the later Beolabs.
    One thing I haven't seen discussed about their respective merits is that with the actives, the "sweet spot" for listening is some 20 cm higher because of the amp down under. The Pentas are rather directional vertically, and the passives are best enjoyed on a rather low seat or sofa, unless you can sit far away from them.
    Someone else can discuss the differences between the various active versions, I always forget which was which...
    -mika
  • 11-05-2008 10:44 AM In reply to
    • Christian
    • Top 100 Contributor
    • Copenhagen, Denmark
    • Posts 626
    Re: Penta advice
    Physical difference:
    Mk1: Line Phono plugs and Power input 4-pin DIN spring loaded contacts. Display: Yellow.
    Mk2: SpeakerLink and PowerLink. Display: Yellow.
    Mk3: SpeakerLink, Phono and PowerLink. Display: Green.
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
