koning: you can try to clean the laserlens
Thanks for your quick answer! I tried to clean the lens with a microfuse cloth.
But it doesn't work (ok, I don't know, if I did it right without taking the whole piece apart...).
A cleaning disc will not work, too, because the disc wouldn't start spinning.
BTW.: I have read the other posts concerning this problem and did all the hints before writing this new post. As I understood it right, in most of the other errors the discs started spinning but the CDs were not detected as a CD so the players turned into pause.
My discs (all slots) do not spin.
Thanks, JOV
