Latest post 10-23-2008 6:00 AM by avus17. 5 replies.
Page 1 of 1 (6 items)
  • 10-20-2008 4:23 PM
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Beovision 3-32 - Screws for attaching the contrast screen
    Hello Forum,
    I am looking for the size/part nr. of the 4 screws that are needed to attach the contrast screen to the Beovision 3-32.
    We dismanteled the screen, cleaned it and somehow the screws got lost...
    Any hint is appreciated!
    Thanks in advance
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 10-20-2008 5:53 PM In reply to
    Re: Beovision 3-32 - Screws for attaching the contrast screen
    hi ralf,
    i cant find the part number right now ,
    incase this helps ,excluding the head, the length of the screw thread is 17mm, they are the wide angled thread type (similar if not the same as woodscrews) but with a flat tip rather than a pointed tip , outer edge to outer edge of thread is 4mm, ive probably made this sound more complicated than it is.
    regards jason
    jason
  • 10-21-2008 10:48 AM In reply to
    • kallasr
    • Posts 1,077
    Jason,
    thanks for the details!
    I will try to find some.
    Ralf
  • 10-22-2008 5:29 PM In reply to
    you must have been cleaning it for ages to have forgotton where you put the screws, sounds like a thorough job Laughing
    if you do get stuck, ill order you a set and pop them in the post for you, no charge
    jason
    jason
  • 10-23-2008 4:49 AM In reply to
    • kallasr
    • Posts 1,077
    Jason,
    thanks for the very friendly offer, I will try here first.
    Yes, the constrast screen ist very clean now...   ;-)
    Actually, the story goes like this:
    Our first Beovision 3-32 (DD, ML) is defect (see other thread), I brought it to a B&O dealer. Diagnosis: broken tube.
    Then we had the idea to take the dolby digital modul and put it into our second B&O (same type nr., no extras, just ML) and decided to take it (the second one) to the dealer. My wife: "Wait, let me clean the screen first!". Ok, so I took the screen off, put the screws somewhere (probably at the same place where all the single socks are...).
    I brought the second Beovison 3-32 to the dealer and then the service guy said: modules are sort of married to the chassis, so you can't take one module out and put it into an other tv set - we need a new tube (1.300 Euro!), using the tube of the second chassis (so we could at least have our main tv set in the living room back) costs 400 - 500 Euro...
    Can anybody confirm the "marriage" issue??
    We won't do the repair, it is not worth it, because tvs are 4-5 years old, used (spare) tube, no warranty etc.
    We will sell the normal (no extras) Beovision 3-32 and the defect one (probably on ebay).
    And then, we don't know yet, set-up, see signature, but a Beovision 4/5/7/9 is out of our budget. We have been looking at Loewe (nice integration with active B&O speakers, remote controls mac mini and dreambox, too) and are even thinking about AvR + LCD (+ir trans to keep the Beo 4).
    Maybe, for the beginning: BS 3000 + BL 6000 as music system, TV + AVR + BL8000 + Sub as 2.1 system.
    Thanks again for your offer, very kind. I will send a pm you if there is a need - and I am willing to pay the costs of sending - at least!
    Best regards
    Ralf
  • 10-23-2008 6:00 AM In reply to
    Let me know if U need a service guide for BV7 32" I can mail it to U.
