Latest post 10-19-2008 12:31 PM by Dillen. 2 replies.
Page 1 of 1 (3 items)
  • 10-19-2008 9:52 AM
    Beovision 8800 spare parts required
    I have an old Beovision 8800 (circa 30 years old) that until recently was working perfectly. It has developed a fault where it becomes difficult to tune in, wiggling the aerial cable jumping between snow on the screen and a very blurry image. It picks up sound ok.
    It has been in to an offical B&O repair centre and they tightened the coax plug, but say the problem is with the tuner, and they can not source spares. Does anyone know of a way that I could get the set repaired? I understand that it is beyond economical repair, but holds sentimental value, looks good (if a bit retro), and has great image when it works.
  • 10-19-2008 11:13 AM In reply to
    Re: Beovision 8800 spare parts required
    Die Bogener Martin would properly know.
    After reading his great post on MX/LX I think that tuner board needs to be cleaned and fresh capistors.
    Your B&O repair just want to exchange the board instead of finding the fault on it.
    As for the value its better to go with the LX/MX range.
  • 10-19-2008 12:31 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Hi and welcome to Beoworld !  Yes -  thumbs up
    What you have is definitely one of the nicer of the older models. I understand that you would like to keep it going and I am almost sure that someone with quite a bit more knowledge regarding TV's than I, will be with you shortly. Die_Bogener, as Friedmett suggests but Tim and Nick also springs to mind.
