Latest post 05-30-2009 5:46 AM by Gerd. 1 replies.
Page 1 of 1 (2 items)
  • 05-30-2009 4:59 AM
    sound and volume setup on beocenter 2
    I wrote last week about my broken beovision 4 screen and whilst that is being sorted I would like just to use my beocenter 2 for playing audio only through beolab 8000 speakers. I have tried to set up sound through the unit but it keeps saying that I can only adjust the volume via the tv which I have taken out .I have the speakers on the av out using RCA leads on the switch box, as I do not have the connection through my media box of the beovision 4 therefore not using din leads. The volume blasts out on max.What am I doing wrong?
    Many thanks for all your support
    Kam
  • 05-30-2009 5:46 AM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    Re: sound and volume setup on beocenter 2
    The AV out is a fixed level, you can't adjust the volume!
    Connect the labs to the PL-socket instead
