Latest post 05-18-2007 1:40 PM by Jandyt. 5 replies.
Page 1 of 1 (6 items)
  • 05-17-2007 7:48 AM
    Serene incorrect sync with BC6000
    Can anyone tell me when the Serene syncs with BC6000 why it imports some numbers correctly but adds the country code to others. This makes the numbers usless as they will not dial automatically with the country code added in front. There seems to be no rhyme or reasn as to which ones get added to.
    Any help would be appreciated.
    Patrick
  • 05-17-2007 5:46 PM In reply to
    Re: Serene incorrect sync with BC6000
    I can't remember which way it happens, but mine did this. The phone still worked though! That was in the UK though. maybe your system is different.
  • 05-18-2007 12:29 AM In reply to
    Peter, what is really odd is that it does not put +61 in front of all the numbers, only some. I am trying to work out why this is the case so i can remedy it.Thanks
    Patrick
  • 05-18-2007 1:52 AM In reply to
    Is it those which start with a 0?
  • 05-18-2007 11:57 AM In reply to
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    I didnt know it could sinc with the Beocoms. Wow have I missed something. I nearly bought one when the first came out but didnt because it wouldnt sinc as first thought. When/what did it change?
  • 05-18-2007 1:40 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Patrick, I might be wrong, but check whether the entries in the 6000 are personal or common and check in the Serene whether they are entered under House or Mobile.
    In the UK, you can dial area code and number OR country code (0044), area code and number and still get the same result.
    Andy T.
    Poor me, never win owt!
