Hi there, I'm new around here and I'm hoping someone can help with a problem I'm having with my BeoCom 6000 system. I know there are some similar posts on here already, but I thought I'd give all the info about my specific situation.
I have had a system with two handsets working fine for five or six years with a connection to a PSTN base. I have recently decided to add another handset to the system and decided that the easiest way was to get another Mk 1 handset via ebay. When I received it I charged it up and switched it on and realised there were numbers stored on the phone, so I did a handset reset by presssing DOT 7 0 0 0 9 and now I can't get the handset to register to the PSTN base.
I have been switching the base off for a few mintues, then pressing the button on the back so that it's open for registration of handsets and then switching the handset on and it just says NOT REGISTERED. When I go through the menu it finds the right base, but when I select it it asks for the PIN code (which I'm assuming is 0000), but then I get REGISTRATION ERROR. Is there something I'm doing wrong?
I obviously have a lot of numbers stored so I am reluctant to reset the whole system, plus I am worried that I will generally mess up the current setup and I won't have any working handsets! If I power down the base for a while will it lose all the numbers stored?
If anyone can help me in any way I would be most grateful.
Very best wishes to you all,
John
