When you say "the display on 1 side is not working" I am assuming you are talking about one speaker display not working ?
If so have you moved the powerlink cable from the working speaker into the other speaker to test the cable ?
If the cable is not the fault, then this is certainly fixable.
Does anything appear in the no working display ?
