Got a Cona for my CX100s. Haven't opened up the box yet, but want to know if the Cona speaker can suffer from foam rot? Or is the speaker using rubber instead of foam?
What can/should be done with a Cona for renovating? Replacing capacitors in the cross over?
Regards Nis
