        1st March February 2012
	    Latest post 11-23-2009 4:48 AM by Hildebrand . 2 replies.
								    |  11-20-2009 12:39 AM |  |
									                 Hildebrand
 Joined on 12-29-2007Phoenix, ArizonaPosts 66 |
										    Grettings all... Just recently acquired a used BeoMedia 1 to add to my setup ( BV4-50, BS1, BL1, BL4000, BL6000)  After looking at the installation guide for software version 3.0 I noticed that it shows the BeoMedia being connected directly to the BeoVision.  I understand that the VGA being connect directly to the BeoMedia being required but shouldn't I be connecting the S-Video and Audio outs into the BS1 under say V.Aux inputs along with the Masterlink going between my BS1 and BM1? Also curious does anyone in regards to the USB and Firewire connection on the unit, can an extrenal HD be connected via them in order to hold the music, photo, video files?  Or can the BeoMedia access a Network Storage Drive?   The default 250GB is rather small and seeing that the largest ATA Ultra-133 HD available seems to be 500GB there's really not much room for upgrading in order to expand the internal storage. Regards, Hiller       BeoVision 4-50 MkII,  BeoSystem 1, Zektor Switch, DTS box, BeoLink Passive, BeoVox Cona, BeoLab 1, BeoLab 3500, BeoLab 6000, BeoLab 4000, BeoLab 4, BeoLab 3000, BeoMedia 1, BeoMaster 5, BeoSystem 3 Type 9621 |  |
									                 jk1002Joined on 04-16-2007Boston USAPosts 1,620 |
										    It has windows underneath so yes a lot can be done.   http://forum.beoworld.org/forums/28.aspx   If you poke around the PC forum, or the general one you may find some instructions. BS9000, BS2300, BC2, BL2500, BL3, Bl2, BS1, BV8, BC4, A8 |  |
									                 Hildebrand
										    Thanks for the heads up on the PC forum....forgot all about that one! Hiller BeoVision 4-50 MkII,  BeoSystem 1, Zektor Switch, DTS box, BeoLink Passive, BeoVox Cona, BeoLab 1, BeoLab 3500, BeoLab 6000, BeoLab 4000, BeoLab 4, BeoLab 3000, BeoMedia 1, BeoMaster 5, BeoSystem 3 Type 9621 |  |
						     Page 1 of 1 (3 items)  |
