I don't find ir codes for sony str da or db 2000 es.(can't find on remote central) I have tried to read out the ir (with an external ir sensor connected to the module) from the sony remote rm pp412, without results i can use. I see the ir string and i have try to change the time pulse. Who is specialist to read out ir codes from a remotecontrol? Thanks for any help
