Latest post 09-23-2008 3:45 AM by BMGHB. 5 replies.
Page 1 of 1 (6 items)
  • 09-22-2008 12:42 PM
    PS3 as a DVD player with BV8 - smooth operator?
    Dear all (especially jk),
    I'm replacing my Philips ("chipped" so that it works with Beo4). Options are used DVD1 or PS3. Now, I do have AppleTV and I know it works fine to control it by Beo4 through PUC. Is it as smooth/logical to operate the PS (as it is to operate the ATV or DVD1)? Does the PS3 "remember" the spot where I left the other day when watching a film?
    My main interest is to use it simply as a DVD player...
    Thanks.
  • 09-22-2008 12:48 PM In reply to
    • matheyl
    • Top 500 Contributor
    • Joined on 04-18-2007
    • French Alps
    • Posts 228
    Re: PS3 as a DVD player with BV8 - smooth operator?
    If you need a dvd player, why buying a PS3? I sold a DVD1 last year for 220 euro.....
    Sheers,
    Laurent.
    Avant 28 DVD, BC2, 2300, BL2500, 8000, to name a few...
  • 09-22-2008 1:59 PM In reply to
    I'd pay 220€, yes, but then again PS is around 400€ and better AND gives a blueray-bonus as well as possibility to play...
  • 09-22-2008 5:42 PM In reply to
    If I understood correct, the PS3 has a blue tooth remote and you buy a third party one? I am thinking the question is what remote works best with the STB and then in a nd step question arises can the STB be loaded to the BV8 (which I am pretty sure it can).
    http://www.remotecentral.com/articles/ps3-ir-remote.htm
  • 09-23-2008 1:09 AM In reply to
    Hi, I thought PS3 can be controlled by Beo4 (that STB/PUC includes the codes) - similarly to the ATV?
  • 09-23-2008 3:45 AM In reply to
    It can. But the Beo4 or the BV8 can not send BlueTooth codes. So the link above is some sort of BlueTooth ------> IR code converter and you need it. But i have heard from several people that it works very fine.
    BeoVision10-46MKII,BL3,BL2,BS8,Beo5
