Latest post 10-04-2008 12:22 PM by Medogsfat. 6 replies.
Page 1 of 1 (7 items)
  • 10-03-2008 6:49 PM
    • modart
    • Not Ranked
    • Joined on 10-03-2008
    • Posts 1
    BeoLink 7000
    How do you change the bateries and where do you get them?
  • 10-03-2008 7:16 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Re: BeoLink 7000
    Batteries in the BeoLink 7000 are intended to be changed by an authorised service center only.  You'll have a merry timetrying to get them for yourself, and then soldering them in.
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 10-03-2008 7:59 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: BeoLink 7000
    If you are handy with a soldering iron it isn't too difficult. I have done this successfully - as have other beoworld members. Simply buy a compatible AA 4 cell battery pack, There is nothing special about the original Ni Cad pack fitted to these, try searching ebay for battery packs intended for rechargible remote control model cars etc.....
    Welcome to Beowor;d.
    Chris
  • 10-04-2008 3:11 AM In reply to
    Re: BeoLink 7000
    Agreed. Mine has a new battery set in - we used the 1000mAh ones from Maplins as the original batteries are 600mAh or similar. We were not sure that the charger would like the types available now - 2000mAh and higher - so chose the smallest value available. They work perfectly. Cost was about £10 for a packet of 12 I think and I had a lot of spare batteries!!
  • 10-04-2008 4:41 AM In reply to
    • ridax
    • Not Ranked
    • Joined on 04-16-2007
    • Posts 44
    Re: BeoLink 7000
    Medogsfat:
    As far as I remember there are 5 cells in the battery pack?
  • 10-04-2008 11:35 AM In reply to
    • Ben
    • Top 500 Contributor
    • Joined on 12-28-2007
    • Taunton, UK
    • Posts 131
    • Silver Member
    Re: BeoLink 7000
    You'd better hurry and buy your replacement NiCads soon.... If you're in the EU then the sale of these are being restricted under a new directive, as of the 26th of last month!
    I'm not sure if NiMH can be swapped in as an alternative without modifications to the charging circuit.
  • 10-04-2008 12:22 PM In reply to
    • Medogsfat
    • Posts 4,045
    Re: BeoLink 7000
    ridax:
    Medogsfat:
    Embarrassed
    OOPS, yes there are 5 Ridax. I'm fairly confident that someone has successfully done this using NiMH batteries too.
    I'm getting old.
    Chris.
