Latest post 09-22-2008 12:52 PM by Piaf. 3 replies.
Page 1 of 1 (4 items)
  • 09-21-2008 11:21 PM
    • Piaf
    • Top 150 Contributor
    • Joined on 07-08-2007
    • Victoria, British Columbia
    • Posts 409
    Beogram 1602 Dustcover Installation
    I decided to restore the dustcover of my Beogram 1602 and believing that this straight forward turntable should not be too difficult in removal  of the dustcover, I proceeded.
    Wrong, with the screws loosened, the clips FLEW off and now I am having a terrible time trying to get the dustcover back in place.
    The dustcover now looks most presentable, but I simply can not get the dustcover back where it needs to be.
    Is there any secret to how this can best be accomplished? I have the manual but it is of little real help. Give me a 4000 series anytime as they are so much easier to work on!
    Jeff
  • 09-22-2008 2:26 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram 1602 Dustcover Installation
    You are not alone with this discovery, Jeff.
    Start at the center and mount the center plastic holder.
    For the sides, do one side at a time, let the spring hang on the outside of the groove at the lid, mount the holder and lift/rotate the spring into place using pliers.
    A 2-minute job when you know how.
  • 09-22-2008 4:56 AM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Dillen:
    Been there, done that! Ouch!!
    Poor me, never win owt!
  • 09-22-2008 12:52 PM In reply to
    • Piaf
    • Posts 409
    Thanks Martin, as always for the information.
    I don’t know if what I did was a good idea or a waste of time that just happened to work, however in complete frustration I decided to take off the entire back panel and then attempt to assemble the dustcover lid.
    With the back panel off, getting everything together was a lot easier. I had literally been struggling for 3 hours trying to get everything back together…. it was a lot like trying to grab Jell-O, but with the back panel off, it took only a few minutes to assemble the dustcover and spring.
    Jeff
