I have recently purchased a pair of RL140. The guy selling them, said the bass wasn't perfect indicating woofer rubber problems and yes, both woofers in each cabinet suffers from foam defect.
I would like to try replace the foam myself, but would like to try out on a nother system first. Therefore my question is:
Which other Red Line speakers are using the same 16,5cm/6½" woofers as the RL140? I eventually will trey dind a smaller/cheaper Red Line speaker with same woofer as the RL140 to try out the replacement of foam.
Best regards
Nis Sorensen
Denmark
