Hi guys
I am a first time poster on here but have been very appreciative of advice on the forums in the past. I have a query about stylus, and its not the one about where to get new ones!!!!!!
1. Are there specific stylus that are only meant to be used with tangential beograms? Or alternatively are there stylus that can be used on both linear and tangential and if so which are they please. If some do fit on both is there a chance of damaging my records?
2. I have a MMC20S that I am looking to utilise on a higher spec than the BG 3000 I have (the really old one with the plastic front and buttons), which other beograms would accept this stylus, I am sure I have seen a tangential BG advertised with a MMC20S but can't remember where. Specifically interested whether it would fit a 5005 or a tangential 3000.
3. Is there a list anywhere (not including the soundsmith one which only recommends their stylus models acceptability) that actually lists which stylus can be used on which system please.
Thanks for your help in advance
Havenboy
