Latest post 09-13-2008 4:59 PM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 09-13-2008 2:46 PM
    Radio reception on B&O 7700
    I have tried connecting a wire to the external antenna jack but with no effect on reception,any help would be very appreciated
  • 09-13-2008 4:07 PM In reply to
    Re: Radio reception on B&O 7700
    To see if it is working, try plugging a TV aerial in it - there should be a co-axial socket.
  • 09-13-2008 4:37 PM In reply to
    I'll have to go buy an antenna and see if that works. I did try clipping a wire with an aligator clip on the end of it to the center pin but nothing changed
  • 09-13-2008 4:59 PM In reply to
    They normally work if you put a screwdriver in the hole actually!
