BeoVision 9 + 4x BeoLab 5, and suddenly installed thin Power Link cable (only left/right channel audio and speaker relay - brown coax, green coax and yellow, without white coax, grey and pink) to each speaker.
There is a terrible warning at user manual - IMPORTANT: Use fully mounted Power Link cables only – not the very thin type! If the wrong type of Power Link cables are used, the loudspeaker will not play. If in doubt, ask your Bang & Olufsen retailer.
Is there a acceptable solution without replacing cable?
Thanks!
