Latest post 05-19-2007 7:26 AM by 9 LEE. 1 replies.
Page 1 of 1 (2 items)
  • 05-19-2007 6:55 AM
    • chodna
    • Not Ranked
    • Joined on 05-19-2007
    • Posts 1
    • Silver Member
    RL 140, wrong technical spec under products
    I am not sure if this is the place where I put corrections to the information under Products, but anyway here it is.
    The technical specification for RL 140 under Products is not correct. The type is 6501, Power is 140 W and dimensions is 70x50.
    Filed under:
  • 05-19-2007 7:26 AM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: RL 140, wrong technical spec under products
    All done. Thank you for pointing this out! Smile
    If you have any more corrections, please do let us know as we always like to make sure every bit of info is correct. You can use this form to do so, and all comments are welcome!
    Many thanks again
    Lee
