Latest post 09-09-2008 7:22 AM by Tom. 1 replies.
Page 1 of 1 (2 items)
  • 09-09-2008 4:33 AM
    Sound without picture ?
    My current set up consists of a Beo vision 5 TV and Beo lab 5 speakers, is it possible to listen to Digital radio Via my Sky box without the TV having to be on ?
  • 09-09-2008 7:22 AM In reply to
    • Tom
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Luxembourg
    • Posts 3,175
    Re: Sound without picture ?
    Yes, that is possible. Use the P-Mute function on your Beo4, then the screen switches off and normally Speaker-Mode 2 is activated, if that is the default audio speaker-mode. This has to be done every time you want to listen to digital radio. On a Beo5, you could programm a button to switch on radio and mute the picture at once. Ask your dealer about that if you have a Beo5.
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
