Latest post 09-04-2008 2:56 AM by joeyboygolf. 3 replies.
Page 1 of 1 (4 items)
  • 09-04-2008 1:51 AM
    Replacement Doors for a Beocenter 2500
    Hi guys,
     First time posting here on Beoworld but I have to say I've learned a great deal reading posts over the past several months.  Thanks for all the great information.
     I've been in the market for some great B & O deals and recently picked up a very nice Beocenter 9500 (have been wanting one since the 9000's first appeared; gorgeous product!!)
     My Brother is getting B & O fever too and purchased a Beocenter 2500 but one of the glass doors is missing.  The open and close mechanism seems to work OK though.  Can these be easily replaced and if so, how would we go about it and how much should we expect to spend.  I was hoping we might be able to send away for a replacement door and install it ourselves but after weeks of internet searching, I can't seem to locate a parts supplier.   We are both located in Southern Cal.
    Any information you can offer would be greatly appreciated.
    Thanks, Peter
    Filed under:
  • 09-04-2008 2:26 AM In reply to
    Re: Replacement Doors for a Beocenter 2500
    Your local B&O dealer is able to supply a door for the 2500. In the UK they cost around £40 each and should be similar cost in the US.
    Regards Graham
  • 09-04-2008 2:34 AM In reply to
    Excellent, thanks Graham,
     Hopefully they will also be able to advise me on installation.
     Regards,
     Pete
  • 09-04-2008 2:56 AM In reply to
    Simple to install, will take longer to open the package than to fit the doors!
    One tip..........wear gloves when handling the door to avoid fingerprints on the inside surface.
    Regards Graham
