Latest post 09-05-2008 7:39 AM by Dillen. 6 replies.
Page 1 of 1 (7 items)
  • 09-02-2008 11:24 AM
    Problem with B&O Television Type:- 3747
    I have a problem with my B&O Television (Type:- 3747 Serial Number 0578183) in so far that I can, not now, switch an Auxiliary on. In this case the Freeview box. What happens is that, upon pressing the TV button on remote to swithch the Auxiliary on, an 'analogue' station switches on and keeps scrolling across the screen. Also the two small red 'lights' which indicate that the Auxiliary is switched on, do not light up.  A strange phenomenon occurred the other evening in that we managed to get the Auxiliary to work but for some unknown reason it switched off, causing the picture to scroll as previously mentioned, when the advertisements came on and then switch on again when the programme restarted; without any input from us.   Would anyone have any idea what could cause this behaviour?   With many thanks for any advice / help you can offer.
  • 09-02-2008 9:19 PM In reply to
    Re: Problem with B&O Television Type:- 3747
    Can you confirm that this is an LX2500 ?
  • 09-03-2008 12:41 PM In reply to
    I am afraid that I cannot, nobby, as the only information of any use on the label at the back of the set are those mentioned in my original enquiry.   Ie.Type:- 3747 Serial Number 0578183.
    If you could give me a hint where to look for 'LX2500' or a similar model No. I will do so.
  • 09-03-2008 4:12 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    On the top surface if I remember correctly.
  • 09-04-2008 5:24 AM In reply to
    Yes, you are so right.     The only place one does not look is the obvious one.
    YES it is a Beovision LX2500
  • 09-05-2008 6:37 AM In reply to
    Problem has been resolved.      Cause:-  Faulty SCART cable
  • 09-05-2008 7:39 AM In reply to
    • Dillen
    • Posts 5,008
    Oh, good job !
    And thanks for posting the result.
