Latest post 08-29-2008 3:20 PM by Dillen. 1 replies.
Page 1 of 1 (2 items)
  • 08-29-2008 12:35 PM
    Beogram 1000 How to change the Belt??
    Hello to all,
     i have an Beogram 1000, but i dont know how to change the belt?
    Its not possible to put off the turntable.
    And ive heard, that its realy difficult to change the belt, because theres a lot of metal inside.
    Cóuld anybody help me??
    Thanks and greets from Germany
    Baolu
  • 08-29-2008 3:20 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram 1000 How to change the Belt??
    You cannot lift off the platter. Or at least that would be very hard.
    From within, losen the belt from the pulley near the motor and feed it through the hole in the metal base plate. Catch it from above and loop it free of the platter.
    Mounting is the reverse.
    Take a look inside (2 screws to remove the bottom cover) and I'm sure you will see how.
