Latest post 08-22-2008 4:49 PM by Peter. 6 replies.
Page 1 of 1 (7 items)
  • 08-22-2008 10:30 AM
    Beo 5 Programming
    Well Down to The Programming , most of the functions and programming seems quite  easy the only thing that problems me at the moment is the channel  programming  , well which command is for like number 1 ? number 2  etc?
    If possible does anyone have a whole list with details about what command on the programm is what?Would be very usefull for anyone that needs to know what is every command on the programm .....
  • 08-22-2008 12:02 PM In reply to
    Re: Beo 5 Programming
    Well after some tries etc  , completed the bro5 programming etc  , but when i press to download it to the remote after some loading it says :
     WRITETIMEOUT ......
    Anyone knows why this shows up at the end?
  • 08-22-2008 12:28 PM In reply to
    Well Tried it On a Different Computer With Windows Xp Instead and at the time when its about to download the configurations to the beo5 It Just throw a blue Screen and Crashes....Anyone know what can be the cause for This ?   I am using  1.32a Firmware and 1.30 prog....
  • 08-22-2008 1:44 PM In reply to
    Try a simple configuration first and work up! The newest firmware is 1.34a but this can only be obtained by being online via the dealer as far as I am aware.
  • 08-22-2008 2:50 PM In reply to
    Well the Problem seems to be my software  witch is version 1.00  afterall , well i guess nothing much i will be able to do then with this one as it cant finalize the beo5
  • 08-22-2008 4:15 PM In reply to
    Anyway to Close this Issue asswell if anyone got the update , as i already have the prog to...update it To 1.30     Would be much apreciated.....
    Email me at  gobboss@hotmail.com
  • 08-22-2008 4:49 PM In reply to
    The 1.30 program is a new version - still 63MB but the important bit is the firmware update which you seem to be only able to get when on line at a dealer. 1.34a.
