Thanks guys
I have tried tiurning on and off, several differnt reocrd types. The thing is that if I start the record later on i.e. start it at half way through, it still does not make it to the end, I may try timing ti to see if the time playing is the dsame on each accosion.
Thanks for the tips guys, hoprefully one of these will solve it, I have downlaoded the 7002 manual and this should help.
Cheers
Sean
