Latest post 08-10-2008 1:16 PM by ChrDH. 2 replies.
Page 1 of 1 (3 items)
  • 08-10-2008 7:11 AM
    • AT
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Posts 187
    Advice needed about to replace an MX5500 with an MX7000
    Dear All,
    I wish to ask You about a possibility, I've just received.
    Currently I have an MX5500 TV, which I really like, with a BL7000, so as You can see, I prefer the two way systems :)
    My "problem" is, that today I've just received a very good offer for a two way(!) MX7000 TV, and I'am not able to decide, is it worth the replacement?
    Thank You for Your answers in advance,
    AT
  • 08-10-2008 7:16 AM In reply to
    Re: Advice needed about to replace an MX5500 with an MX7000
    Better sound and newer tube - as long as it is cheap! MX TVs are fetching very little at present so I would keep the MX5500 as well! Smile
  • 08-10-2008 1:16 PM In reply to
    • ChrDH
    • Top 150 Contributor
    • Denmark
    • Posts 493
    I got a MX6000 which i bought for £200 one year ago via DBA.dk, and I often see MX7000 going for the same price, so under all circumstances, it would be a cheap upgrade to buy a MX7000 as main TV and use the MX5500 as link perhaps? if you got room for it keep it. The MX7000 is a upgrade sound wise, and I also think it is more servisable with its modular internal components, very easy to fix, just change the circut board.
    br
    Chr
    Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
