1st March February 2012
Latest post 08-11-2008 8:29 PM by Tom. 18 replies.
08-01-2008 4:46 AM
halid
- Joined on 02-19-2008
- Posts 124
Hi, I am about to get new rear speakers for my system. I have been looking at both the BeoLab 3s and the BeoLab 4s but I am not 100% satisfied with any of them. Does anyone know if there will be some new speakers released this autumn ? Best regards Hans
9 LEE
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
If you weren't happy with BeoLab 3's as rears - were they switched on?!!  I can only really suggest BeoLab 9 as rears if the 3's didn't float your boat. What are you using as fronts? Lee
mjmedlo
- Joined on 06-07-2008
- Arkansas, USA
- Posts 384
I have BL 8000 as surround and BL4s as rear surround; I also have a pair of BL3s in a bedroom for listening. . If you are comparing things to the BL5s you will not be happy with anything else. I used the BL8000s mostly because of the way they looked and they fit better with my decor. I think when you're looking at BL3 and up it's a matter of taste and aesthetics as much as anything. . . assuming of course you're using BL 5s in the front
I'm ready for something new that I actually want to buy!
halid
- Posts 124
Hi, thanks for all comments. I'm sorry I left out some information in my post. - I have Beolab 6000 and a Beolab 2 as sub. Everything is bought in 2004. The 6000 most for the design which I think fits my room perfect. With the Beolab 2 I also think the sound is really, really good. Dreaming of BeoLab 5s in the front some day of course. - The reason I am not satisfied with 3s or 4s is the design. Since it is 250 km to my nearest dealer I have not have the opportunity to listen to either one of them. Please keep on posting. Best regards Hans
joff135
- Joined on 04-17-2007
- North Somerset, UK
- Posts 62
I have Lab 3s front with a Lab 2 and Lab 4s rear...and my set-up is great imho. My Lab 4s are fitted facing downwards about 8 ft up on the back wall above the sofa. For watching tv films, videos and dvds the Lab 4s are perfect...if however i had wanted to listen to music on Speaker 4 Mode then i would have bought another pair of Lab 3s for rear...although i do sometimes play Speaker 4 Mode at low/medium volume levels and it still sounds good to us!
halid
- Posts 124
Thanks for all comments. I use a 7-40 MK III as TV in this room. A pair of 5s would be great in the front and the 6000s great as rear spakers. The problem is that the sofa covers the entire wall. I need some rear speakers that I can place on the wall. Still confused, keep on posting. Regards Hans
beoben
- Joined on 04-18-2007
- Germany
- Posts 189
Tom ist right! the bl 3 would overpower the bl 6000. you´ve said you have a space problem caused by your sofa! Isnt there enough space for bl 6000 another solution would be to get the 6000´s with the new wall mounting
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Hans's sofa covers the whole back wall. 6000s on wall mounts would look a bit daft half way up the wall above his sofa! Might as well dangle them from the ceiling like the crazy russian 8000 picture.
halid
- Posts 124
Thanks for all comments. I have decided to go for a pair of wallmounted Beolab 4 since my room is pretty small and I am more than pleased with my sound as it is. Best regards Hans
halid
- Posts 124
Hi Joff ! As I wrote I will place a order on a pair of 4s tomorrow. I was wondering how you have attached your 4s to the wall, facing downwards ? I would like to hide mine behind the sofa, and face them upwards instead. Is that possible ? Do I need a wallbracket ? Regards Hans
beoaus
- Joined on 04-16-2007
- Melbourne, Australia
- Posts 445
Have a second look at the Beolab3's. They will not over power your other speakers, you can easily raise or lower their dominance. As surround sound progresses you will be thankful of having the additional oomph.. beoaus.
Tom
- Luxembourg
- Posts 3,175
Hi Hans! I think the 4s are the right choice. I would not hide them behind the sofa but put them at the height of your ears in viewing-/ listening-position and I wouldn't attach them downwards, because they look better the other way. Just my 2cents...
Music washes away from the soul the dust of everyday life. - Berthold Auerbach
Page 1 of 1 (19 items)
