Latest post 08-06-2008 11:35 PM by ThaiBinh. 3 replies.
Page 1 of 1 (4 items)
  • 08-05-2008 5:28 PM
    Hello from "Clueless about TX2"
    Hello everyone,
    I found a B&O Beogram TX2 turntable out on the curb a couple years ago in a paper bag marked "Free". Although I listen to an occasional record (on a really wimpy, lame record player my parents bought from JC Penney), I had no idea how incredible my free find was. I think it still works, but it just needs some fixing. (It probably didn't help that the paper bag was really heavy, and kept bumping against my leg as I carried it home.)
    I haven't really gotten around to figuring out what needs to be done because I've been busy with other projects, but I would like to start fixing it now. I was wondering if anyone could suggest a primer on record players (ex. It came with a "pre-amp", but I don't know what that is, and what I would plug it into).
    I will eventually post more specific questions in more specific forums, but I just thought I would start out with this introduction.
    Cheers!
    -ThaiBinh
  • 08-05-2008 5:31 PM In reply to
    Re: Hello from "Clueless about TX2"
    Did you secure the MMC-pickup before walking away?
    /Ola
  • 08-06-2008 1:49 AM In reply to
    I think the main problem has been identified! If it does not have a cartridge - the needle on the end of the arm - this will be expensive - think $200.
    Worth seeing what it does - see if it works mechanically - does the platter turn when you switch it on - you will need a record on the platter - and does the arm move?
  • 08-06-2008 11:35 PM In reply to
    Hello Ola and Peter,
    Thanks for your replies. I think that I do indeed have the cartridge (which is just the needle, right?), but perhaps it was damaged during the transport to my apartment? I can't remember if the previous owner had "protected" the needle for transport (again, I found the record player a few years ago, so my memory is a bit hazy).
    The platter does turn, and the arm does move, although it causes a clean record to skip...
    I have posted an entry in the BeoGram forum with a link to a video detailing what happens here:
    http://forum.beoworld.org/forums/thread/134108.aspx
    Thanks again for your help!
    -ThaiBinh
