Latest post 08-04-2008 5:20 PM by djram. 4 replies.
Page 1 of 1 (5 items)
  • 07-31-2008 7:40 AM
    • djram
    • Not Ranked
    • Joined on 08-26-2007
    • Posts 78
    • Gold Member
    Convertig a mcl transceiver to a vx sensor.
    I saw on beocentral that the vx sensor looks just like a MCL transceiver, except that the mute and timer buttons are missing. Would it be possible to use the MCL as a vx sensor if some of the wires are connected to the appropriate plug? I do not have enough insight and technical skill to understand if or not.
    I would appreciate if someone could have an idea on what wires to use and what type of plug to use. Then I could try it with a spare mcl transceiver I have at home.
    Hans
  • 07-31-2008 8:10 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Convertig a mcl transceiver to a vx sensor.
    Should be possible. You only need 3 pins: IR - 5V - ground. You  can also use the Vishay TSOP 7000. It`s a 455 kHz receiver.
    Stefan
  • 07-31-2008 10:33 AM In reply to
    • djram
    • Not Ranked
    • Posts 78
    • Gold Member
    Thank you Stefan.
    The user guide says it is a Ø 3.5 mm plug. I do not know if it is a 3 or a 4 pole. I also do not know what wire to connect to what pole. Maybe this is in the vx 4500 service manual. That one is not on this site but I have made an inquiry.
  • 07-31-2008 10:38 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
      I have three sensors that look identical. One is a VX sensor which I have connected to my Beoport, another came with a remote controlled loudspeaker switch, and the third is part of a dealers demo unit.
    Strangely, the power supply for the demo unit is opposite polarity than the one for the speaker switch, so be careful.
    Andy T.
    Poor me, never win owt!
  • 08-04-2008 5:20 PM In reply to
    • djram
    • Not Ranked
    • Posts 78
    • Gold Member
    After spending some time with a multimeter and a soldering iron, the mcl transceiver is now converted to a vx sensor. Now I can remote control the vx 4500.
