Latest post 02-25-2009 2:39 PM by AT. 3 replies.
Page 1 of 1 (4 items)
  • 02-23-2009 10:08 AM
    Beolink 7000 - 120 V and 240 volts
    Hi - I have a Beolink controller and the plastic piece where the handset rests of the charger has broken.  have been unsuccessful in finding a replacement piece and now am going to buy a stand. The one i have found has a 240 V power adapter. Will it work here in the US with the hanset I have which runs on 120V? All I really need is the stand - not the power adaptor. Any suggestions?
    Glenn
  • 02-23-2009 1:58 PM In reply to
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    Re: Beolink 7000 - 120 V and 240 volts
    A picture would help as I am not sure what you have.  However I would think it would be easy to take the workings from the US 110v and put them into the 240v one to fix your problem.
    Brian
  • 02-23-2009 4:03 PM In reply to
    Thanks - i think it will work as well but was wondering if anyone had experience with them.
  • 02-25-2009 2:39 PM In reply to
    • AT
    • Top 500 Contributor
    • Posts 187
    Just a question: Do You mean the floor stand?
