Latest post 08-01-2008 2:20 PM by stotty1111. 2 replies.
Page 1 of 1 (3 items)
  • 08-01-2008 3:59 AM
    • Faz
    • Not Ranked
    • Joined on 06-30-2008
    • Skelmersdale
    • Posts 36
    Would You try this?
    Would anyone consider or have they tried an acyrlic scratch remover like this?
    http://www.edirectory.co.uk/pf/880/mia/d/xerapol+scratch+remover+for+acrylic/pid/4389346
    on for example a MX4000 screen
    MX4000 Glossy Black /Beo 4 / Motorised Stand
  • 08-01-2008 8:06 AM In reply to
    Re: Would You try this?
    I use a metal polish to remove scratches from the plastic "glass" on watches.  Works very well indeed.
    Ray
    Я люблю Банг и Oлуфсен
  • 08-01-2008 2:20 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    hi there
    i have used silver polish on the acrylic penta bases to great effect - silver polish tends to have finer grain size than most other metal polishes - another alternative might be jewellers rouge although don't know how to acquire it
    salut a la france
    tony s
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
