Latest post 07-31-2008 2:57 PM by Coolskin. 5 replies.
Page 1 of 1 (6 items)
  • 07-31-2008 7:06 AM
    • geomich69
    • Not Ranked
    • Joined on 04-13-2008
    • THESSALONIKI , GREECE
    • Posts 22
    16:9 broadcasts on normal 4:3 MX tv
    Is it possible following any key sequence (beo4 or beolink 1000) to see the whole picture of a 16:9 broadcast on a normal B&O MX television? My old SONY does this with a key on the remote! I wonder....if the - not so old B&O - can do this !
     thanks for your help...
    George
    Filed under:
  • 07-31-2008 7:17 AM In reply to
    Re: 16:9 broadcasts on normal 4:3 MX tv
    I can do it on my LX TV's but it is done using an option on the STB providing the signal,  not using an option on the TV itself.
    Simon
  • 07-31-2008 8:57 AM In reply to
    If what you mean is to zoom in ( to fill the whole screen ), then yes, it's possible. On Beo4 go to LIST > FORMAT and then choose FORMAT 2. I f you don't have it on the list, you should add it first. Also, it's possible it won't work because it's not a widescreen tv, but it's worth checking out.
  • 07-31-2008 9:02 AM In reply to
    • geomich69
    • Not Ranked
    • Posts 22
    Thanks a lot but I meant if you can zoom out: for example see movie that is broadcasted in 16:9 supressed , in letterbox format. Because all programs now are shown with "longer faces" , if you know what I mean.
  • 07-31-2008 2:08 PM In reply to
    what mx model do you have? i have a mx4002 masterlinked to bv3 with sky, and when i select sky on the mx i too get the squashed picture. I have asked a similar question before and was told 16:9 wont work on the mx4002 but does work on the mx4200. If anyone know different please let us know.
    Never Mind The Ball-Cocks www.markmossplumbing.co.uk
    A labourer uses his hands
    A tradesman uses his hands and his head
    A craftsman uses his hands, his head and his heart
  • 07-31-2008 2:57 PM In reply to
    Our MX4002 is connected to a HDR1 and Digital Decoder.
    HDR1 recordings directly from the Digital Decoder 16:9 are shown with "long faces".
    But... a similar recording done with standard terestrial signal (from the outlet on the wall) gives a nice letterbox format.
    It beats me how come.
    Oh, in this setup I can watch digital in the bedroom too. But then like the HDR1 digital recording faces will be longer then normal. To eliminate this the digital decoder must be set to 4:3 mode instead of 16:9. The right and left side of the image won't show. They are cut of to fill the screen i think.
    geomich69:
