Hi all.
I've just got a Beocenter 7000. Everything appears to work as perfectly, except the balance control works the opposite way round to how I'd expect - ie: moving the control all the way to the left means sound only comes out of the right speaker and vice versa. However apart from this the balance control works as it should, just "reversed". It's the same on both sets of speaker outputs.
Yes, I have checked that the speaker at the left of the unit is plugged into the left speaker output, and same for the right.
Is this a peculiar common feature that's known about this unit, or is it something odd like someone (not me) has put it back together incorrectly?
I'd be very interested in your thoughts.
