In order to deactivate the PIN code system you must first key in your previously chosen four-digit code, and then key in the ‘0000-code’, which disables the function.
While BeoLab 5 is in standby…
- Press ss, ss, and STOP in quick succession on the Beo4 remote control. The indicator light shines intermittently red (1 sec.) and green (0.5 sec.).
- Within 10 seconds, press the touch field on top of the loudspeaker you wish to deactivate. The loudspeaker confirms your selection with a sound signal.
- Key in a your previously chosen four-digit PIN code*. The loudspeaker confirms each digit with a sound signal.
- Press GO to enter your four-digit code. The loudspeaker confirms this with a sound signal.
- Key in the digits 0 0 0 0 on the Beo4 remote control*.
- Press GO to deactivate the PIN code system. The indicator light shines red again – indicating that the loudspeaker is in standby and ready for use.
If it is not accepted the loudspeaker emits a sound signal, and you will have to start over again with the ‘0000 code’.
