Latest post 07-12-2008 2:05 PM by bumble. 2 replies.
Page 1 of 1 (3 items)
  • 07-03-2008 2:21 PM
    Repair of Beogram 8000
    Does anyone know of a repair shop in the US that is capable of repairing the model 8000 turntable?  I've tried 2 shops and neither could fix it.  Also, if someone could advise me on how to get the capacitor kit, that would be much appreciated too.  Any help would be appreciated.
  • 07-03-2008 3:30 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Repair of Beogram 8000
    Contact member Dillen (Martin) and he will certainly provide a capacitor kit along with full fitting instructions. He can also supply a brand new tacho disc (in S/Steel) as yours will certainly have started to fail if it is the earlier cellophane type.
    Can I also suggest repeating this thread to the Beogram section where it is likely to gain a better audience for your problem (Dillen seems to spend a bit of time on there helping other beogram ownersSmile)?
    Chris.
  • 07-12-2008 2:05 PM In reply to
    • bumble
    • Not Ranked
    • Joined on 05-21-2008
    • USA
    • Posts 21
    Did you try SoundSmith in NY?
    Bumble
